flysky fs-gt3b
flysky fs-gt3b
i just bought the flysky gt3b and installed it in my stampede i am running a team checkpoint 3.5 brushless sensored motor and a novak gtb esc. the problem i am having is tha every time i turn on my truck it goes full throttle and ive tried to adjust the settings on the radio and it helps a little but not enuff . any advise would help p.s : Ive tried to set the fail safe but that didn't help
+1 That is what it sounds like to me also. When setting up the ESC to find your transmitter's neutral/maxium throttle/maximum brake, be sure to have the throttle trim set to set to zero, and the throttle EPA set at 100% in both directions.
After getting the throttle trim set to 0, be sure to push the "Enter" button on the toggle/multi function wheel or the GT3B will not save your settings; likewise with the EPA settings. You must push the "Enter" button to save any setting that is changed.
Do all this before turning on the ESC to calibrate.
