Forgot to turn off my JR 8103. Left it on for 8 hours!!
Well,this is a first for me. After leaving my 72mhz 8103 tx in the closed foam case with the antenna down, the module sure was pretty darn warm. I haven't had a chance to field check it yet, but I'm afraid that it might give me a decent looking test on the ground with JR's recommended 50- 60 yard test , but I'll discover that it's not good for 100-200 yards in the air by losing a plane. It's hard to do 100-200-300 yard ground tests and be able to see precise and instant aileron or elevator surface movements from that far with the plane when it's sitting there on the ground or on top of a ladder.
Though I suppose I can try to probably rig up a tripod with a telescope and try to do such long distance kinds of ground tests, maybe somebody can tell me what their experience has been with leaving on a 72mhz JR tx for hours like I did....and what I might expect.
My Feedback: (26)
Nothing will happen other than paying attention so it doesn't happen again. I left my 9303 on and when I discovered it the screen was blank. I panicked and though the back-up battery also died. Recharging the unit proved me wrong and the model memory was still intact. If you damaged the RF module than get a replacement but I don't think you did.
It bothered me enough that I didn't want to wait until Monday to call Horizon just to ask.....Soooooo..... with today being my day off from work, I went out to a field today with my electric trainer strapped to the top of a 6' wood step ladder I brought along with me. I then walked 300 yards out into the field to test the radio function. (which is further then my old eyes can fly a plane anyway) Using a telescope mounted to a camera tripod at that distance, I was able to observe all radio input from my transmitter working, with all control surfaces moving and responding to the sticks.
Tried that twice with family members on cell phones and can tell you that it's confusing and doesn't work because the conversation goes something like this; "I just moved it. Did you just see it move or not?" ...or, "What do you mean you think you saw it move just a little? - I just finished moving the stab up and down 4 times!" or, "You think it twitched before I even moved the stick? Is it twitching or moving now?" ....etc. With a 50X target spotting scope focused on the plane, I can push the stick and see exactly what the control surface is or isn't doing at any time. You put bright orange or red plastic clamps clipped onto the control surfaces too, and it's easy to see movement even without a top quality scope.
