Futaba 8FG Programming Question
I'd like to program the right slider to give me app. 3 clicks of down elevator during landing (like a condition I guess). Having a hard time with this. Is there a link to a YouTube video (I have looked) that I may have missed. Thanks for your help in advance- Andy
You want to set up a p-mix with hardware as the master and the elevator as the slave. When you select hardware, it will then put up the screen where you select the hardware component is controlling the mix. Select the desired slider. Then set the mix curve as needed to give you the amount of elevator movement when you move the slider.
