Futaba 6014HS acting crazy on initial start up
My Feedback: (212)
NC
I have a new plane I've set up with a futaba 6014HS and a smart-fly EQ10, Savox high torque digital servos and two seperate 2300ma A123 batteries. I went yesterday to set everything up to hopefully go out and fly her today. Three different times, I turned on the 12Z transmitter first, then powered up the flight pack batteries, the servos just went crazy, moving every which way. I turned the switch off on the airplane and then back on and everything responded just as it should. It's acting like there isn't a proper binding of the radio when first turned on. What could be causing this? Thanks
Are the servos jittering or going full throw? Jitters can be full charged batteries; once some of the charge is drained they will stop. If they are not, for troubleshooting I would eliminate the EQ10 and put the servos direct to the receiver, and of course rebind.
My Feedback: (41)
Change it back to normal mode. Unless you are flying ultra in your face smack 3D helis you will never see the difference between normal and HS mode. Also, you did not mention your servos, but the HS mode requires digitals servos as well.
Just put it in normal mode and go fly!!
