Spektrum TM1100 telemetry module set-up
I have been having great problems getting my 14 month old DX6 radio to bind with my new Spektrum TM1100 telemetry module.
Following the Spektrum binding instructions, both receiver and telemetry module go into bind mode okay with flashing LED's, but only the receiver light becomes steady after binding...the TM1100 module light just goes out and I get no telemetry.
Ideas tried over the last 3 weeks:-
I have over the weeks been in correspondence with the US HH support and they have been helpful but we have now seem to have reached an impasse. Anyone else seen these problems and found a fix?
https://www.youtube.com/watch?v=60lebZoewU4
- firmware upgrade to the DX6
- distance increase between module and receiver of > 3 feet when binding
- distance increase of DX6 to both rx and TLM module of > 10 feet
- Another two, AR6115e receivers tried
- a new AR6255 receiver (recommended) tried
- a Y lead and bind link to eliminate possible problems with the TM1100 bind button
- a replacement TM1100 module!
The AR6155e receiver is not listed as compatible with the TM1100 in the manual. The AR6255 is listed. I'm not sure what telemetry you are trying to get with this setup but according to the Spektrum Telemetery Compatibility chart, there is very limited functionality available for your configuration. That doesn't explain why you are not getting anything at all though. The only thing I can think of that you didn't mention is that you have to have your sticks centered and the throttle full down when you bind.
http://spektrumrc.com/ProdInfo/Files/SPM_Telemetry_Compatibility.pdf
It would appear, although I stand to be corrected, that modules sold in Eu are only DSM2 but are sold as DSM2/DSMX. Most with the older Spektrum transmitters have DSM2 / DSMX capability so that although you think you have a DSMX module its actually DSM2. If like me you have the newer DX6 then its is DSMX only and thus will not work with the TM1100. The larger TM1000 module is DSMX however and thus will work with the DX6. But I still haven't found a TM1100 which is fully DSMX...have you?
Andy
Thanks for your input...most useful but baffling! Perhaps you tell me why I'm in trouble then? I have tried two from different UK sources and neither worked. Both had DSM2 on the labels unlike the TM1000 which is marked with the X symbol. They bound ok with my DX6i but not with the DX6. I have now bought a TM1000 and it bound fine with the DX6. But I'd still like a TM1100 because of its smaller size.
No, I have no idea why you're having trouble. I would simply contact our UK office so they can straighten things out with you.
All the units we built were DSM2/DSMX even though the label says DSM2 on very early production items (DSMX had been in internal use for a year, but we did not announce nor enable it in consumer DX8s it so all the labels only said DSM2).
You bought them from a genuine Spektrum dealer?
Andy
Andy
Andy
Andy
UK Service: http://www.horizonhobby.co.uk/service-advice/index.html
DE Service: http://support.horizonhobby.de/servi...taktieren.html
The DE office has more resources (much larger selling area) so they may be able to help better than UK. They were the "point office" for EU 1.8.1 changes and information, so they may have better answer as well.
And they speak English.
Andy
Andy
Andy
Andy
This was the reply from HH in Germany, but I'm not sure I'm much further forward really. I kinduv knew this already:-
"This problem is caused by the new DSMX-protocol which is no longer compatible with old DSM2 receivers and the TM1100 since the EU has changed the norm for 2.4 Ghz-frequencies EN 300 328 1.8.1"
So why are the TM1100's been sold as DSMX compatible?
Regards
Regards
I just spoke with the tech director.
Update the code in your transmitter to the latest version. This may correct the issue.
There were some TM1100's built that did not work with all transmitters. We caught most of them before they were shipped out, but apparently you got some.
If the update of your transmitter doesn't correct it, please return it and the TM1100's to Horizon UK and ask them to contact me regarding them. They know my e-mail.
They will work fine with most other transmitters, it's just that the combination of your transmitter code and their receiver code that doesn't play well together.
Andy
Andy
Andy
Andy
A s/ware update to the DX6 was the first thing I did weeks ago. Its now on 1.05a. That didn't cure the problem. I have sent all 3 TM1100's back to the vendors now so its going to be tricky to test any upgrades that Horizon UK might do!
Regards
And to the UK too, since they didn't seem to know what was going on either AND they never phoned me back with a solution, hence my posting here.
I'll see if I can get hold of another module to try here although very reluctant to invest any more since these difficulties.
Regards
Regards
Regards
Regards
This came in from Horizon Hobby today:-
"We have spoken with Spektrum about this matter. The TM1100 is a DSMX. The TM1100 is not compatible with the European Union Spektrum DX6 and DX7 G2 versions transmitters and possibly the DX18 tray transmitter. There are no plans by Spektrum to update the TM1100 to make it compatible with EU DX6 and DX7 G2 transmitters."
So if its true then there is little I can do. Seems a pretty poor deal to me?
Regards
Regards
It doesn't really help me in a desire to find a compact Spektrum telem module! Plus your only going to get more disappointed buyers as the sales of the DX6, DX7 G2 increase and more people find out that the their TM1100 sold as DSMX compatible isn't! It really behoves Spektrum to make all current kit on sale to be compatible with legacy and current transmitters? Surely its only a firmware upgrade for the TM1100?
Regards
Regards
