Anybody ever experienced permanant interference with 72mhz FM receivers?
I came back into this hobby after a 7 year absence last year, and I'm finding that all of my JR FM receivers suffer chatter and signal interference in either of the 2 different channels I use while using either of my two different JR8103 radios. I also received a couple of free stress tests too when the prop started turning unexpectedly and wouldn't stop until I pulled the plug! The solution is that I put PCM receivers in my planes to make everything work fine. Evidently, there is major interference in the area I live.(...and no, it's not that I don't have the modulation set properly on my radio).
Just curious, has anybody else experienced the same type permanent signal interference like this so that you can't ever use any standard FM receivers in your planes? Bummer.
Electric planes? I have never tried a Im assuming a 600 or 700 receiver on an electric plane, but I know speed controllers are noisy electrically. They might not be able to reject the noise. I fly 72mhs but no electric on them.
Yes, they're electric, and 600, 700 receivers. Didn't bother trying my 9 or 10 channel receivers. They are FM too. Though I don't have to be running the motor to get the interference. Everything starts twitching without me even touching the sticks! So far, I haven't had a problem flying them with PCM.
Just a long shot, but have you changed all your light bulbs to CFL over the past few years? They are notorious for EMI.
Also, you might search for the problem by
a) turning off everything in the house to see if the interference goes away
b) tune a portable FM radio down to the bottom stop and use it to search for the source of the interference. It should hear ESC noise, if that's it.
Thanks for the input. I was just more curious about the "why" of it more then anything else. It's just good for me to be educated about these things and to be cautious with any purchases I make in the future with ANY kind of radio system including 2.4 Can you imagine jumping with both feet into a new $700 JR 2.4 system, only to find out that I can't use it because of interference!! I would need to check into anything first before just assuming it's OK where I live.
I'm not talking about interference at the workbench under the lights or near the radio. It happens from one corner of my backyard to the 100ft far opposite other corner of my property at my driveway. -Twitching without even touching the sticks. The solution is to use PCM receivers. All 6 of those that I have work 100% just fine. Thankfully, 72mhz PCM receivers can be bought for cheap these days being everybody is bailing out of 72mhz. Just bought another for $16 this week.
