Futaba T8J
Futaba T8J
Hello., I have my flaps on the 3 position switch "C". My question is , how do I program different flap settings for the positions.....I have looked thru the manual and can't find anything......thanx in advance!! Rick
If you want the 3 positions to be "Flaps Up", "1/2-Flaps", "Full flaps down", it's a simple thing.
Use the Aux-channel function to put the desired flap channel on the switch you want to use. Make sure the sub-trim for that channel is set to 0%.
Move the switch to the "1/2-Flaps" position. Adjust the physical linkages to put the flaps at the amount of deflection you want for 1/2-flaps.
Move the switch to the "Full Flaps Down" position and adjust that endpoint to give you the desired deflection.
Move the switch to the "Flaps Up" position and adjust that endpoint so that the flaps are in the proper stowed position.
Done!
Done!
