Remote settings
Remote settings
Obviously new to this. Got my son a nitro Exceed Infinitive . The remote has 6 settings I don't understand. I've learned ST=Steering and TH=Throttle
I have 2 switches and 4 knobd.
1 switch is ST, the other TH
you can switch between r and n on both. What is r and n? Run and Neutral?
Then the knobs. One is TH, the other ST
they both can be adjusted between 0-10.
The ST has a D/R . What is D/R?
And what does the 0-10 adjustments change? Sensitivity maybe?
The other knobs are trim, I got that
Thanks in advance
Thanks in advance
Those switches are for reversing the steering servo and throttle servo (or ESC). Sometimes, depending on orientation of servo and/or linkage, the Servo Reverse switches are used to get the servo to go in the "right" direction needed.
