Plane setup ??
Plane setup ??
So, I programmed a spectrum 8 tx for my little profile plane.
I have been out of the hobby for quite a few years, and think I made an error!
I only set the plane up with conservative throws, and no active dual rate switches.
So, I used servo travel to adjust my throws. I assume that is wrong, because I would have to go set up my travel adjustments again for every DR switch.
Another way, I assume I should adjust my travel for max throw desired. THEN, use dual rates to lesson throw in "sissy" mode.
So, 100% dr is all out, and conservative flying would be 40% or whatever??
Even better, have the servo travel set to max and then lengthen the control horns at the servos to reduce surface travel. Also, if your transmitter allows, dial in some expo which will soften the response when the stick is first moved off neutral. I prefer expo over dual rates as when dual rates are set to the lower end you loose resolution.
