Help with using Transmitter/Receiver with motors
Reply
Old 09-17-2017, 03:07 AM
transatlantic
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Help with using Transmitter/Receiver with motors
Hi
I'm trying to build my own RC tank type steering thing where the steering is done via a motor on each of the back wheels. I bought the following items (Note I need this to move slowly, hence the 60 RPM motor) :
(Sorry - I'm not allowed to post links yet)
Flysky Fs-T6 2.4G 6 Channel Radio System
Overlander 3300mah 7.2v NiMH Battery
12v 60 RPM Motor (Micro Gear Box Motor Speed Reduction Gearbox Centric Output Shaft) (eBay item number:122671122349)
Kamtop RC Speed Controller 320A High-frequency Drive System Electronic Speed Controller
I've hooked everything up, but the problem I am having is that when I switch from forward to reverse using one of the thumb sticks on the transmitter, the motor stops and will not do anything until I return to the neutral thumb position, wait a bit, and try again. Yet, if I go forwards, flick back to neutral, wait 1 second and then go backwards, it works?
It doesn't seem to like me rapidly switching from forwards to reverse .. yet I need that behaviour for the tank type steering behaviour I'm going for.
Is this due to a problem with the configuration I have bought? ... possibly because the motor is 12v and the battery is only 7.2v? ... I thought this would work fine, just that it would be slower? Or is it due to the motor controller not being suitable for my application?
transatlantic is offline
Contact Us Archive Advertising Cookie Policy
