JR 28X Trouble :(
JR 28X Trouble :(
Hi Guys,I've just been stung real bad ..So I purchased a 28X from a guy in Australia (Second hand) who said the radio was in good condition.. when it finally arrived however this was not the case.
The top left 3 way toggle switch was completely broken, and the aerial was also broken off in 3 places.
Initially the radio powered on , however it was getting channel interference all over the place from the broken switch (I could hear it beeping when I gave the radio a shake ) probably from the broken switch.Eventually the touch screen interfaces hung completely, so I pulled the pack in an attempt to reset, and now its completely dead. it will not turn on at all , and I'm stuck with a $2K brick door stop Of course the seller is adamant it was in good condition when he shipped... no surprises there.I've contacted JR Americas service centre , however haven't had a response. I see that Horizon no longer offer repair for JR either , so now I'm stumped as to where I can send this unit. I'm happy to pay for the repair.Does anyone have any ideas??
Second question.. Does anyone know if this radio has a fuse on-board? What should the voltage of the on-board CR2302 be?Has anyone with any technical knowledge opened one of these up and can tell me some of the things to check please? I fear I will not be likely able to get any repair services from where I am.Any help much appreciated.Cheers
radiosouthrc.com ? Radio Control Systems Repair, JR, Pro-Line, Futaba, Radios, Service, Airtronics, Spektrum, Radio South
These guys are experts here in the U.S. If it's fixable, they can do it. Sorry for your trouble... those radios aren't cheap either... no doubt. It's hopefully worth fixing, as in good shape they're one of the best out there. Good luck with it.
My Feedback: (17)
MO
This off the main topic, can the JR28X be used with the 6 meter tx module? I would like to purchase a new JR radio to replace all my 10X's. I fly on the 6 meter band and have no use for the 2.4 ghz band. Our club has had so much interference with the 2.4 over the years that I would never feel comfortable using the 2.4 band. I have never had an issue on the 6 meter band.
Of course the card has to be removed, and put into a computer, with the correct micro SD adapter, or slot in their computer, and you need to tell them what files your wanting.
It cannot be done when the card is in the radio.....LOL.... and you'll need a micro SD adapter or slot in your computer on your end to get the files to your card, then into your radio.
The card is easily removed from the radio, just remove the back panel of the radio.
If you can send me these files, I'll write to you in pm with my email.
Thank you and Happy New Year!
I didn't say I could do it... I said it could be done. Sorry if you were mislead. If you go to the JRamerica.com , and/or Horizonhobby.com You really should be able to find what you're looking for. Just enter your radio model into Google.com and that will lead you in the right direction. Good luck with it.
I need all files from microSD
TO Maestro: Since you are in Italy, neither JR-America nor Horizon will help you; probably no point in
telephoning or emailing them. .
Do you have a 28X ? You can download the 28X operating software from the JR-America web site.
They have version '0005' for downloading. It is not the latest version but quite good.
You can download version '0006' from the JR Japan web site. It is the latest version I use with minor
changes. compared to version '0005'.
That is all you should need. Follow instructions for installation on the JR America, or JR Japan web site.
My 28X bricked and I need to replace the internal card.
[email protected]
Thanks in advance
Jonathan
