futaba t7c battery replacement
Most if not all modern battery charger are equipped to charge Nicad/ Nimh/ Lead acid/ Lipo and Life batteries ( unless you have a Lipo only charger ) but one has to read the charger's charging instruction to be able to access the Life charge function or do a YouTube video search. What brand charger do you have ?? .
My charger is around 5 years old and its a Chinese no name. I have looked for a life function but I don't think it has it. I doubt my charger is on YouTube. and buying a new charger is not in the near future.
Tried the Futaba route first. all I got was a cya answer. gibberish about possibly voiding the warranty. this on a discontinued radio that hasn't seen warranty in a decade.
Steve, Try this forum if you haven't yet. It's supposed to support questions like you have, I'm with Karol. The voltage of Lipos is too high. Life's may be OK. I would stick with the NiCads or NiMhi's. Dan.
http://www.rcuniverse.com/forum/newt...ewthread&f=125
I got the okay from Bax the Futaba rep some time ago to use a Life battery in my Fut 8UAF and have been doing so for several years now with absolutely no ill effects.
