Futaba 9c Mix Problem
All
I use a Futaba 9cap with the Futaba 8 ch 2.4 module and FrSky Rxs..I want to mix the bottom 25% of the throttle to turn on landing lights on channel 7 . Over 25% the lights go off. What is the best way to do a mix in the Tx?? Cheers
Update....
I think I figured it out.
I put an old Picoswitch into ch8 on the Rx, ( it's a Frsky TFR8).
Programme set-up
Programme set-up
- End Point...Ch8, Aux.100/100
- Reverse ...normal
- Programme. P. Mix6
- On
- Throttle to Aux 2
- Pos1 -20%,Pos2 -15%, Pos3 +22%, Pos4 +51%, Pos5 +70%
- Mix on
- Mas: Throttle
- Slave: Aux2
- Link: Off
- SW: F
- Position : NULL (this means that it is always on)
