Can I use a 7.2v battery with reciever and servos?
Reply
Old 09-26-2003, 10:08 PM
theaugerfiller
theaugerfiller's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Can I use a 7.2v battery with reciever and servos?
Hello,
I've noticed that most of the time the voltage for servos and receivers is normally 4.8 or 6.0. I'm using a 7.2v motor so I would need a 7.2 volt battery. Can the Rx and servos use this voltage too?
Theaugerfiller
theaugerfiller is offline
Old 09-27-2003, 12:10 PM
GalenB
My Feedback: (18)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Can I use a 7.2v battery with reciever and servos?
It sounds like you are flying an electric. If this is the case then your electronic speed controller (ESC) will likely have a plug for the receiver power (receiver battery eliminator). This plug will be at the correct voltage for the receiver and the servos -- usually 4.8 volts. Your eflight power packs will range from 7.2 volts for LiPo packs to 9.6 volts for 8 cell NiCds...
GalenB is offline
Old 09-27-2003, 04:07 PM
Lynx
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
7.2 connected directly to a servo will fry it in a hurry.
Lynx is offline
