hv servos mixed with lv receiver
Reply
Old 03-29-2018, 05:26 PM
flier60103
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default hv servos mixed with lv receiver
is there going to be a problem if you run your servos on 7.4 volts and the receiver (frsky) on 5 volts? Just thinking of a situation where a separate regulator is used for the receiver that is less than the nominal voltage (2 lipo cells).
flier60103 is offline
Old 03-30-2018, 05:22 AM
kdunlap
My Feedback: (12)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don't get the question. But if you are asking "can I run a normal receiver at 7.4 v?" then yes, you will burn out your receiver due to current draw from the servos. If you are asking can I buy a board that powers the receiver at 5V and the servos at 7.4v these are readily available but expensive. Smart-Fly puts these out. PowerExpander Eq10E That's why folks just opt for the HV receiver.
kdunlap is offline
Old 03-30-2018, 10:00 AM
Truckracer
My Feedback: (19)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Have you checked to see whether the frsky receiver is compatible with HV? Most newer receivers are. If that is the case, run everything on HV.
Looking at a variety of frsky receives, the ones I looked at are all rated for up to 10V even though not specifically saying they are for HV.
Truckracer is offline
Old 03-30-2018, 10:56 AM
tntpooof
tntpooof's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
no issue with rx voltage .. but your 7.4 will not have all the speed toque or power you might want or need ..but a ubec and some moving rx plugs will be needed.as in signal wire stays with rx and ubec powers servos.if you can follow.
tntpooof is offline
Old 03-30-2018, 11:43 AM
pilotpete2
pilotpete2's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The FrSky receivers I'm familiar with are rated for up to 10V input, so they're fine on 2S lipo.
And no, you won't burn up the receiver due to the supposed higher current with HV servos. For a given amount of torque, a HV servo will draw a little less current than one rated at the same torque at 6V.
The question as to whether there's a problem with too much current for the receivers power bus is determined by how many, and what torque ratings the servos have and other factors.
Pete
pilotpete2 is offline
Old 03-30-2018, 11:49 AM
Truckracer
My Feedback: (19)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Pete
+1
Old 03-31-2018, 11:25 AM
kdunlap
My Feedback: (12)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The stall current is what you need to worry about. Here’s a link to an example of stall current at various voltages. https://www.servocity.com/hs-7950th-servo With a non HV receiver you need to make sure that the connectors inside can handle not just the voltage but the current as well. Worse case is stall current. Sorry if I wasn’t clear before.
kdunlap is offline
Old 04-03-2018, 03:30 PM
Truckracer
My Feedback: (19)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
While I'm not sure about the Frsky receivers, most receivers these days use multi plane boards with more than (1) power carrying land between the various servo pins. I can't say I've ever heard of a receiver having a board problem with regards to current on the power buss. With regards to HV and servos, for a given amount of torque, with HV there will be less current than an equivalent torque LV servo.
