Airtronics SD-6G trans toggle switch
Reply
Old 04-08-2018, 10:33 AM
Hesp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Airtronics SD-6G trans toggle switch
The retract toggle switch on my Airtronics trans needs replacing. As Airtronics is mostly out of business I need a source for the retract toggle switch. Any help would be most appreciated .
Hesp is offline
Old 04-08-2018, 02:13 PM
EloyM@twc.com
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have Airtronics transmitter switches, including the Retract Switch for the SD-6G. $6 shipped!
However, you might consider replacing the long lever switch with one with a shorter lever, like the one mounted right in front of the Retract. The shorter handle is less likely to catch on something and get broken off, or broken just in general handling. After all, how many time per flight do you actuate the retracts, if at all?
Your choice. PayPal is OK if you have it: EloyM@twc.com. For check or MO< use:
Eloy Marez, 2626 W. Northwood., Santa Ana CA 92704. Thanks
EloyM@twc.com is online now
Old 04-08-2018, 03:46 PM
Hesp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks so much for your reply. The short switch sounds like the way to go.I'm sure if I had had a short switch to begin with it would not have snagged & bent. When I went to straighten it out it broke off. I'll get a check out to you. Again thank you.
Hesp is offline
