futaba 29 MHz receiver, plastic coated metal case?
Reply
Old 05-01-2018, 03:42 PM
kiwiremote
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default futaba 29 MHz receiver, plastic coated metal case?
I have an old futaba 29 MHz receiver, nothing special about it just a standard looking receiver but the plastic has what I thought maybe just some melted solder dropped on the top of the case but when i try to remove it it seems like it maybe not solder after all as it shows no sign of coming off and it does not quite look right for melted solder, do these plastic cases actually have metal in the middle, i.e is it really a metal case coated all around with plastic?
kiwiremote is offline
Old 05-01-2018, 07:15 PM
grotto2
grotto2's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've seen receivers with an inset in the plastic where a piece of labeled aluminum is adhered. Is this what you're seeing?
grotto2 is offline
Old 05-01-2018, 07:20 PM
kiwiremote
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mine is a fp-r102gr and when i look at photo's from google there is no metal where I see metal, I have metal on the E of BEC but like I said it kind of looks like a splash of solder but when i try to scrape it off I cannot, I wonder if solder did splash on it at one stage a melt the label in this spot so now you see the metal underneath, I think this is the same as you are suggesting?
Old 05-01-2018, 07:51 PM
grotto2
grotto2's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes. Looking at photos on google of that receiver, I can see that the label has a background that is not quite the same tint of black as the actual plastic of the case. This label is aluminum underneath.
grotto2 is offline
Old 05-01-2018, 08:20 PM
kiwiremote
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks, I won't keep trying to scrape it off then.
Old 05-17-2018, 05:22 PM
rcacro
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Some of the really old RC equipment did have aluminum cases with a heavy plastic coating.
John W
rcacro is offline
