eagle Tree Guardian problem
Reply
Old 05-26-2018, 03:08 PM
bokuda
My Feedback: (7)
bokuda's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default eagle Tree Guardian problem
I hope someone can help.
I have a guardian installed in a Telemaster with separate aileron servos on separate channels with a Spektrum system. No matter how I set it up, the ailerons move in the same direction, either both up or down, Servo reversing channels does not solve the problem. I tried an electronic servo reverser, but the connected servo moves randomly with it.
A Y harness has been ordered and I will try that, but am hoping someone has a remedy so that the aileron servos can be used on separate channels.
bokuda is offline
Old 05-26-2018, 07:30 PM
mongo
My Feedback: (14)
mongo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
when i have to have separate ail/ele servos and a stabilizer, i use 2 stabilizers mounted side by side. one for the left half of the plane, the other for the right. also will allow for separate rudder/nosewheel servo channels.(or dual rudders, like in a falcon/bobcat type)
mongo is online now
Old 05-27-2018, 04:34 AM
bokuda
My Feedback: (7)
bokuda's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks. Interesting, but expensive, solution! But it may be worth trying for my 1/4 WW1's that are becoming difficult for me to fly.
bokuda is offline
Old 05-27-2018, 06:25 AM
wnewbury
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Don't the instructions say to physically reverse the location of one servo? Flip it over to aim it the other way?
wnewbury is offline
Old 05-27-2018, 02:28 PM
bokuda
My Feedback: (7)
bokuda's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I do not see that in the instructions and I don't see how that is possible unless one servo is remounted to the top of the wing. Turning the servo 180 degrees as mounted will not reverse the throw.
One solution, might be to move the control horn on one wing so the other side of the servo output arm could be used - and I may just do that if I don't find another solution in the next few days.
There must be a way to configure this as wings with separate servos are very common.
I have emailed Eagle Tree, but have no yet received a reply.
bokuda is offline
Old 05-27-2018, 03:06 PM
mongo
My Feedback: (14)
mongo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
have you turned option #9 "on" in the menu? that is the onboard dual aileron mix
then use option #11 to toggle reverse/normal.
this is all starting about midway down on page 9 of the manual.
mongo is online now
Old 05-27-2018, 08:43 PM
wnewbury
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
looking for where I saw it.
wnewbury is offline
Old 05-28-2018, 03:50 AM
bokuda
My Feedback: (7)
bokuda's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, I saw that. I do not have a PC and Eagle Tree does not offer their software for MACs. However, the manual says the default setting is for wings with two aileron servos.
Thank you for your response.
bokuda is offline
Old 05-28-2018, 02:18 PM
mongo
My Feedback: (14)
mongo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
it does tell you how to use the TX to program it, the pc stuff is just for ease when in the shop.
mongo is online now
