DX8 Servo Travel Adjust
Reply
Old 10-15-2018, 03:56 PM
rkh1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default DX8 Servo Travel Adjust
Trying to help a friend that uses Spektrum DX8 / AR 7010. Setting up plane with dual ailerons nd I need to be able to adjust the travel to equalize the throws. When I go to Travel menu and push stick to right or left I get no movement in either direction. R Aileron is connected to Ail channel and L Ail is connected to Aux 1 and it changed to L Aileron during set up. Any suggestions on how to adjust throws as Im nor familiar with this TX and have tried every thing I know. Thank for your help.
rkh1 is offline
Old 10-15-2018, 04:04 PM
Zeeb
My Feedback: (41)
Zeeb's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is a gold mine of information about Spektrum programming. Be aware that there really isn't any separate adjustment of servo throws on the ailerons that does not come with some issues. Lots of folks will use sub trim which isn't a good idea if there is a lot. So before you try setting throws, try to make the mechanical setup as nearly perfect as possible.
R/C Tech Tips
Zeeb is offline
