Help with servo selection
The HS-81 is a very solid performer.
A good alternative would be an Emax in that size.
https://alofthobbies.com/emax-es-3104.html
I've had very good luck with Emax servos in the smaller sizes.
Pete
Pete
Still one of our best sellers in that category. If you want a more precise servo (since this is a faster airplane) with metal gears then you might look into the new D85MG. Slightly larger, but you can always factor that in when building the model.
