old futaba 2 channel 27mhz AM transmitter question
My Feedback: (19)
I have an older Futaba FPT-2F transmitter on 27 MHz AM. This is the type that has the big printed circuit board inside. I would like to convert it to 2.4 using a Frsky module. Can anyone help me to find where to solder the ppm and positive and negative voltage leads from the module? I know its just easier to buy a new radio that is modern and has servo reversing but this would be used in a vintage sailboat. Any help would be appreciated. Thanks
I don't think it matters with AM. I've run modern 27MHz receivers with my wide band transmitters no problem.
BUT: You have to watch out for old transmitter crystals. As they age they slide off frequency. I had to sort through my transmitter crystals.
My Feedback: (19)
I bought a new receiver on the same frequency as the transmitter. So far using it in a sailboat it seems to be working fine. I will pay attention to the information you gave me about the crystals. Thanks.
