Airtronics SD10GS elevator reversing error!
Reply
Old 06-12-2019, 09:47 AM
dw_crash
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Question Airtronics SD10GS elevator reversing error!
Dear RCU friends,
My new SD10GS radio has a weird quirk I need help with. I am using a 8 channel FHSS-1 receiver. It is setup to use channels 1 and 5 for dual elevators. The issue is that if I reverse channel 1 it also reverses channel 5. If 5 channel is reversed it also reverses channel 1. I can't get it just to reverse one channel.
I also have channels 2 and 6 set to ailerons. If I reverse channel 2, only channel 2 reverses. If I reverse channel 6, only channel 6 reverses. This is what I expect.
Please advise as to correct the channel 1 and 5 reversing error.
thanks
DW_Crash
dw_crash is offline
Old 06-12-2019, 10:55 AM
Thud_Driver
Thud_Driver's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You need to get the model template correct so the elevator channels are mated properly.
Under System, go to Type, under Tail set your model for 2 x EL. Note this will completely reset all your settings. Then you can go into CH Assign and check if your elevators are on ch 1 & 5 or fix it so they are. Now you can properly reverse your channels.
Thud_Driver is offline
Old 06-15-2019, 12:22 PM
dw_crash
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks.....I will give that a try.
dave
dw_crash is offline
