LiPo Recommendation for an Aurora 9X
Reply
Old 07-23-2019, 12:49 PM
Ron Kay
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default LiPo Recommendation for an Aurora 9X
Can anyone suggest a LiPo for an Aurora 9X. Thanks, Ron
Ron Kay is offline
Old 07-23-2019, 02:31 PM
SA Flyer
SA Flyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Pulse 3600 2S is what I got for mine. Do a search for checking out photos of that. Its EC3 leads had to be snipped off and shrink-tubed to fit in the batt compartment. Battery door won’t close unless you buy the expanded size battery cover on eBay.
SA Flyer is offline
Old 07-24-2019, 03:34 AM
pilotpete2
pilotpete2's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Look specifically for a 2S lipo that is designed for Tx or Rx use. A Tx lipo should have a very low C rating to avoid puffing when left fully charged for long periods of time.
a lipo that comes with an EC3 or XT60 plug will have too high of a C rating for Tx use
GForce 2600mAh 2S LiPO Transmitter TX Pack (Futaba/JR) | Value Hobby
You'll probably need to splice on a Hitec battery connector from your old battery, or did Hitec switch to using a servo connector on the 9X battery?
Pete
pilotpete2 is offline
Old 07-24-2019, 04:29 AM
SA Flyer
SA Flyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Pulse battey for Aurora 9X
In a Hitec Mfg forum in RCG, this topic was discussed. I had an image of it that I posted there.
The Pulse battery is a snug fit without the EC3 connectors, but it does come with a JR-styled connector that slides in without issue. Just insure correct polarity when inserting connector.
https://www.pulsebattery.com/collect...y-lipo-battery
The other item that will prevent cutting off any cables is this Expanded Battery Cover for Hitec Aurora 9X.https://www.ebay.com/itm/Expanded-Ba...wAAOSwJWBcULBQ
I have both and both are doing very well. I can use my EC3 charge cable to charge. REMEMBER to change the TX settings from NiMH to LiPo.
Post what you decide to do.
Name:	HiTec Aurora 9X Pulse LiPo Battery.jpg
ID:	2264863   Click image for larger version
Name:	HiTec Aurora 9X Expanded Battery Cover.png
SA Flyer is offline
Old 07-28-2019, 06:37 PM
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Pulse 2550 RX pack. The standard servo type connector will plug right into the pins on the PCB. I balance charge through the EC3 plug.
speedracerntrixie is online now
Old 09-11-2019, 11:30 AM
E-Challenged
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Contact Hitec Support. Batteries America may have a compatible Nimh pack for 9X
E-Challenged is offline
