Can I use a Futaba radio with Jr receiver?
Reply
Old 09-30-2003, 02:21 AM
faisalk
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Can I use a Futaba radio with Jr receiver?
I just ordered a Futaba 9 cap radio. It is on 35mhz frequency. I also happen to have 2 Jr 35 mhz fm receivers. I want to know if they both will be compatible or I will have to use futaba receivers with futaba transmitters?
faisalk is offline
Old 09-30-2003, 02:54 AM
HarryC
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Can I use a Futaba radio with Jr receiver?
Very probably will work together. It is only on 72Mhz in North America that Futaba has created the shift problem, as far as I know. European 35Mhz equipment all works together.
H
HarryC is offline
Old 09-30-2003, 05:33 AM
Raptor^Norway
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No problem!! But be sure to have the same brand crystal as the equippment!!! VERY important!
e.g. Futaba Tx and JR Rx - Futaba crystal in Tx and JR crystal in Rx (both with the same channel ofcourse)
I use a JR 3810 and have both JR, Hitec and Futaba recievers in my planes/helis. No problem at all if you do as I mentioned above! Also it is wise to do a range check to be sure.
Raptor^Norway is offline
Old 10-05-2003, 08:40 PM
Cliffp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Be very careful because I have heard they work on different wave peaks. I'm not sure exactly how it works but one sees the positive peaks where the other uses the negative peaks. Otherwise you wouldn't need to specify when ordering. This is what I have been told, so more expert advice would be in order.
Cliffp is offline
Old 10-06-2003, 07:41 PM
Forgues Research
My Feedback: (7)
Forgues Research's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What your refering to, is negative and positive shift which is a good point but only in North America unfortunately. But elswhere they are all on the same shift.
Forgues Research is offline
