Hitec Eclipse 7
Hitec Eclipse 7
I have a Pitts with four aileron servos (two top and two bottom). Can anyone help with the set up with the Eclipse 7?? Completely baffled!!
thanks
Mark
thanks
Mark
RE: Hitec Eclipse 7
I don't think that radio has enough mixing for 4 aileron servos.
I take that back... you cvould get creative and use flapperon on the bottom and creat your own (P.Mix 1 and 2) on the top. With that radio, the easiest way to do it is with Y-connectors.
RE: Hitec Eclipse 7
[8D] Figured it out!! Bottom wing in channal 1 and top wing in channel 6. Mix channels 1 and 6 with 1 being the master and 6 the slave. Whammo, it works!!
Looking forward to flying this Cermark Pitts with the MVVS 1.6 gas turning an 18x8 Scimitar and TME Smoke system!!!! Heeee Ha!!
CA
RE: Hitec Eclipse 7
Why not set up the bottom wing like any monoplane, (that is using channels 1 and 6)and, either use a 'Y' connector to control the other ailerons on those channels or have them on channels 5 and 7, and mix 1 to 5 and 6 to 7?
-David C.
-David C.
RE: Hitec Eclipse 7
I suppose that would work too. It's just that I was able to set it up as I indicated and and that hurdle is done. Looking forward to flying it.
