Profi 4000 Programming
Reply
Old 10-06-2003, 06:06 PM
jtholley03
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Profi 4000 Programming
Ok
Using the throttle trim as
Up: flying idle
Middle: landing idle
Down: kill
Where do I do this?
jtholley03 is offline
Old 10-06-2003, 07:25 PM
Forgues Research
My Feedback: (7)
Forgues Research's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Profi 4000 Programming
Up: flying idle
Down: kill
Where do I do this?
Simply add more trim authority on the trim lever through the program.
Roger
Forgues Research is offline
Old 10-07-2003, 02:36 AM
radray
radray's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You may also consider using a 3-position switch, which would allow fine tuning of the throttle with the trim lever and even disabling the throttle stick at the kill position if you like. I have experimented with converting the throttle control to flaperon/spoileron control when in the engine kill position.
radray is offline
Old 10-07-2003, 02:49 AM
HarryC
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What’s wrong with the standard method? In menu 1, servo, travel, you should have a default travel of 72%. Adjust the value to make the engine stop when trim is fully back, then on most engines you get the desired effect at mid and forward trim.
If you need more precision use a 7 or 9 point curve (I can’t remember which it is) because travel points 1, 2 and 3 correspond to the three trim positions when the stick is fully back and therefore the engine revs can be set precisely.
For a throttle kill switch go menu 1, control, throttle, fixed value, set to 0% and set the desired switch.
Harry
HarryC is offline
Old 10-07-2003, 11:52 AM
radray
radray's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Harry,
Nothing at all wrong with using the trim lever, I just find it is easier to reach the outside 3-position switch than an inside trim lever when flying and the switch takes care of all engine trim conditions.
Ray
radray is offline
Old 10-07-2003, 03:25 PM
jtholley03
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I was just trying to find an exact setting for each. Kill is obviously the bottom. But rather than full up being an approximated flying idle and something in the middle be approx landing idle. Switch idea is good in that you could set an exact servo position - hadn't thought about that one. I was trying to make the slider act as a switch I suppose.
Thx I will mess with this weekend.
