futaba receivers
Reply
Old 10-09-2003, 06:48 PM
rccub
My Feedback: (184)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default futaba receivers
every time i ask someone what receiver should i use they all say the standard receiver that comes with the flight pack. they are seven channel. my planes are only four or five channel. isnt there a cheaper receiver in the four or five channel catagory. seems kind of a waste. thanks for any help.
rccub is offline
Old 10-09-2003, 08:54 PM
krs
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: futaba receivers
I love the Hitech 555.....super little receiver.
Kevin
krs is offline
Old 10-09-2003, 10:28 PM
charlied123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's the issue. The difference between a 7 channel receiver and a four is only about $15.00. Sooner or later you'll move up to an airplane that has flaps or retracts and you'll spend money on a better one anyway. If you get the 7 channel now you can always move it from plane to plane and you'll save that way instead of having a four , then buying a seven for the second plane. Everytime I try to save by buying the lesser model I wind up spending more later. Just my 2 cents worth. Hope it helps.
charlied123 is offline
Old 10-09-2003, 10:29 PM
charlied123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Tech is 20.00 less than futaba for the same number of channels. That's a good value
Old 10-09-2003, 11:20 PM
3DFanatic
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Unless, of course, you start running PCM. All of my PPM planes use HiTec Supreme receivers.
3DFanatic is offline
Old 10-10-2003, 09:15 AM
Rodney
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You can not go wrong with any of the FMA receivers either, as good or better than any of the others.
Rodney is offline
Old 10-10-2003, 04:06 PM
rccub
My Feedback: (184)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks for all the info. makes sense. just wanted to make sure i wasnt missing something.
rccub is offline
Old 10-10-2003, 05:02 PM
Geistware
My Feedback: (16)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If I am not mistaken, the R127 is the bargain basement futaba receiver for airplanes. Hitec has a great line of receivers that tend to be cheaper.
Geistware is offline
Old 10-10-2003, 06:03 PM
3DFanatic
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah, the RF127 is like HiTec's supreme 7 at $50 more.
Old 10-10-2003, 09:41 PM
KB9STD
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The issue (as far as price is concerned) is that the receivers all use the same decoder chip.The chips are 7 or 8 channel units.When marketing a 4 or 5 channel receiver,the manufacturer only brings out (wires) the 4 or 5 channels.The other channels are there,there just aren't servo connectors for them.So,the cost to produce a 4 or 5 channel receiver is the same as a 7 channel.That's why when you purchase a 4 channel system,it normaly comes with a 7 channel receiver.It would make no sense to put a 7 channel receiver in a 4 channel package,IF they could produce a 4 chanel one cheaper.But,considering they sell many more of the 7 channel version,the 4 channel actualy costs them More to produce.
KB9STD is offline
Old 10-11-2003, 07:57 AM
Geistware
My Feedback: (16)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
THis is a good point. I think that is why we will start seeing the 8 channel unit as standard from futaba. That way, they can incorporate the same receiver for everything from the 9C down. Remember, on the 9C, you only get 9 channels in PCM mode and that last channel is only a two position channel. An 8 channel PPM receiver will work for all futaba transmitters except the 9Z.
ORIGINAL: KB9STD
