Need help now... maiden flight???
Reply
Old 10-11-2003, 01:30 AM
harphunt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Need help now... maiden flight???
I own a Futaba 9c. I'm trying to set up the ailerons for dual rates "using" flaperons (I don't intend to use the flaperons as my plane is a floater. I am using two channels instead of a y-harness). I have the right aileron in channel 1 and the left in channel 6. In setting up dual rates, only the right aileron will respond to the programming commands. In the 'Dual Rates" menu only chanels 1-4 are displayed. How do I set up the left to dual rates like the right side? I hope to fly tomorrow if I can get an answer. I'm not going to use the flaperons as my plane is a floater(Venture60), but I want to be able to trim the left aileron as the right. What am I missing????
Should I set up EPAs first or the dual rates???
Thank you to all in advance. I want to fly tomorrow. This forum rocks.
Harphunt
harphunt is offline
Old 10-11-2003, 11:19 AM
GalenB
My Feedback: (18)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Need help now... maiden flight???
How are you programming the flaperons? I have lots of flaperon models and have not seen this problem... I have an 8U Super -- not a 9C, but I wouldn't expect too much difference...
This may help...
http://www.futaba-rc.com/faq/faq-9c-q522.html
GalenB is offline
Old 10-11-2003, 10:20 PM
harphunt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm a dork... It was 2 in the morning and I was trying to do some last minute programming. Both ailerons work fine. I'm not using flaperons, but am using channel 6 for the second ail servo. Thanks for the response.
PEACE
harphunt is offline
Old 10-12-2003, 01:41 PM
Speedfreek 68
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jaime from Laredo TX. check your atv on your radio pushing the contol arm to the left side.
Speedfreek 68 is offline
