9C & 127DF RX
My Feedback: (18)
RE: 9C & 127DF RX
ORIGINAL: billben55
Will the 9C computers work with the 127 DF Rx? Also, I'm confused about the difference between the 9CAP and the 9 CAF. Do both offer PCM?
Bill
Bill
My Feedback: (16)
RE: 9C & 127DF RX
Ditto.
I currently have a 9C and use a 127DF (PPM...see below) on one plane and a PCM RX on another. When you set up your model, you pick whether or not you want to use PCM. Then when you switch to that model, you need to turn the 9C off and on for the change from PPM to PCM to occur.
We should note that both signals are FM signals. The two are shown as either PPM and PCM by the display on your 9C.
RE: 9C & 127DF RX
billben -
Was looking for the same answer when I wandered into the Futaba 9C FAQ - [sm=confused.gif]
http://www.futaba-rc.com/faq/faq-9c.html
http://www.futaba-rc.com/faq/faq-q341.html
which sayeth -
"This radio comes with the ability to transmit in either FM or PCM modulation. Simply change the modulation type in the parameters (PARA) menu, and turn the transmitter off and back on to transmit in the new modulation. Of course, the receiver must be the proper modulation to operate. A receiver cannot be converted from FM to PCM or back."
HTH
Jim
which sayeth -
HTH
Jim
