Go Back  RCU Forums > Radios, Batteries, Clubhouse and more > RC Radios, Transmitters, Receivers, Servos, gyros
Reload this Page >
can i trust hitech 700 servos on D.P edge? - please help
Old 10-24-2003, 11:36 AM
roy_fisher
Default can i trust hitech 700 servos on D.P edge? - please help
i want to put the hitech 700 on a dave patrick edge plane.
i think the power and speed are more than enough.
they are a bit bigger but i dont care enlarging the holes for the servos.
here is the tech. information:
Operating Speed (4.8V): 0.22sec/60 degrees at no load
Operating Speed (6.0V): 0.17sec/60 degrees at no load
Stall Torque (4.8V): 138.87 oz/in. (10kg.cm)
Stall Torque (6.0V): 173.58 oz/in. (12.5kg.cm)
Dimensions: 2.32" x 1.14"x 2.04" (59 x 29 x 52mm)
Weight: 3.59 oz.. (102g)
i have never had hitech servos so i would like to hear your advise...
thank you very much
roy
Old 10-24-2003, 03:29 PM
visioneer_one
My Feedback: (506)
Default RE: can i trust hitech 700 servos on D.P edge? - please help
ORIGINAL: roy_fisher
Bad choice (except for the rudder, and even there its not the best choice)
These servos are huge and heavy. Consider using the 6xx series or their digitals.
Old 10-24-2003, 08:09 PM
Giant Scale
I would agree the 5645 or 5945 would be a much better choice than the 700. The 700 is a 1/4 scale servo that would probably be better suited for a scale model like a cub.
You want to keep the weight of your plane to a minimum and using a bunch of 3.5oz servos isn't the way to do it. The 5645 digitals cost about $55, are programmable and provide ample torque for planes up to 35% scale. If it was me I'd use the 5645's on the elevator and ailerons, 5945 on the rudder and a good quality analog servo on throttle
Old 10-25-2003, 01:00 PM
roy_fisher
i understand you guys...
do you know a good place exept servo-city that i can buy servos and recivers in a good price?
thank you
roy
Old 10-26-2003, 11:18 PM
Giant Scale
For servos and receivers you can try www.chiefaircraft.com or www.towerhobbies.com
Theres a guy on e-bay I believe his store nameis toms rc simulator I've purchased
brand new futaba 7 channel receivers for around 50 bucks, he also has hitec supreme
8 channel receivers for about the same price. Pretty cheap if you ask me.
