Flight Packs
![](/forum/images/badges/trading_plus_member.png)
My Feedback: (33)
TN
I am about to embark on another Ariplane, the Funtana to be exact, and I am at a cross road, I want to use the same TX that I have my Ultra Stick on, it is a XF-652, it isn't the best radio, but it was my first Computer Radio. I can program more then one aircraft in it, and now I am charged with the task of BUYING more onboard electronics.
What would you all suggest I get to run the Funtana's control surfaces, I'll need atleast 5 servos, should I stick with the NES537's, or go with hitec, or Expert or something less...expensive?
Reciever?.....servos?.....I have a 600mah battery that I am not using, will that work for 5 servos? I put a 1400mah in the stick, running 7 servos and all.
BTW, this is the Hanger 9 .40 Funtana. I will be running a MDS .58 until I can afford a SAito .72.
My Feedback: (24)
TN
i would think the expert they are about the same price as any brand standard servo and they work good i have had some for about 1 year and good as new and the 600 mah battery will be fine they don't use no more mah than a standard servo or you can get a standard hitec flight pack for 99 dollars and the cristle is 9.99 at quantum models sorry i an not the oner and don't want to get in trouble for advertising i just get some stuff from there and he has good prices and the hitecs will be fine on the plane
