Re-angling the detent on the 9CA throttle ratchet
Has anyone done this? The stock ratchet effect is very strong. If I were to re-angle the detent on the throttle ratchet will opening the case void the warrenty? Thanks
Bill
Bill
MI
RE: Re-angling the detent on the 9CA throttle ratchet
What I've done is loosen the throttle ratchet to the point that you can hardly notice any ratcheting. This allows you to put the throttle where you want it, and you don't have to bend the ratchet at all.
Well, I finally took the back cover off and found it easy to either bend the ratchet clip or loosen the screw that holds it in. I have it now so it has a nice smooth ratchet feel.
I went a step further since I want to fly both helis and planes with it...
Remove the screw and flip the ratchet hook upside down. When you tighten everything back down you can just barly feel the ratchet effect and should you ever want it agian in the future you just flip it back. I know people that just removed the metal, but you may want to sell the tx to a plank flyer later who wants the heavy ratchet again.
