Dual Receiver Q's
Dual Receiver Q's
Ok,
I know this ssubject has been looked over many times, I just got though looking through multiple page threads about it...but I have some specific questions:
1. With dual recievers, do they need to be spaced apart any certain length?
2. What about the antennas? Do they interfere with each other at all?
3. How in the world do you do the mixing with 2 recievers? I have an 8103 and a 10X for transmitters. There are (4) non Y ed aileron servos, (2) non Y ed rudder servos, (2) non Y ed elevator servos, a smoke servo, throttle servo, and a fiber optic kill switch.
4. Does anybody have a picture of their setup?
Thats all I can gather at the moment...if anybody could answer those questions it would be greatly appreciated.
My Feedback: (30)
RE: Dual Receiver Q's
Receivers: I space my receivers on either side of the fuse. On occasion, I have placed both rxs within the same LDM strongbox.
Antennas: They need to be run in a non-parallel manner. I usually run one along the base of the fuse and the second one to the tip of the vertical stab.
Rx-1 left elevator servo, 1st rudder servo, 2-left aileron servos, throttle
Rx-2 right elevator servo, second rudder servo, 2-right aileron servos, smoke and kill switch
Hope this helps Elson
ORIGINAL: hover&tork
Wow, very helpful thank you.
I have another question...I plugged both of my elevator servos (one on each half) into the "elevator" slot on both receivers. One was going to wrong ways with the elevator inputs. I went to reverse it and I pretty much knew that the other would be reversed also...I was right and now the opposite elevator servo is operating the wrong directions. To fix this do I need to plug one of the elevator servos into an auxiliary channel and mix it?
I have another question...I plugged both of my elevator servos (one on each half) into the !QUOT!elevator!QUOT! slot on both receivers. One was going to wrong ways with the elevator inputs. I went to reverse it and I pretty much knew that the other would be reversed also...I was right and now the opposite elevator servo is operating the wrong directions. To fix this do I need to plug one of the elevator servos into an auxiliary channel and mix it?
Remember that if they are on two separate channels, it is very important that the trim lever will affect the elevators the same, and this should be tested by moving the trim lever full up and down and making sure both elevator halves track this. The mixer should also track any other mixes or rates that affect the elevator,such as knife edge mixing, dual rates, etc. Make sure you test these. This applies to all surfaces that use multiple channels, and especially any surface that uses two servos each being on a separate channel. Think what would happen if you have two servos driving the rudder, and you adjust the trim or put in a mix and only one servo responds to the trim/mix.
