how too setup spoilerions.7uap
NF, CANADA
Tryin to set up spoilerion ,so that when i pull 3/4 elevator the alerions pop up any ideas .I am using the 7uap futaba
IL
RE: how too setup spoilerions.7uap
Sorry, your 7U can't handle this. You would need an 8U super, 9C or 9Z to do so, using a curve mix with the elevator as master, flaps as slave, first several points as 0, and then at the point you want your spoilerons to "pop" set the mix to the desired travel.
