How to make dual ailerons go into one aileron slot on the receiver?
ON, CANADA
I am fairly new to building r/c planes, although i have flown them before. I am thinking of buying a plane (Potensky Eagle from www.hobby-lobby.com) and I see that it has dual aileron servos. The receiver they tell you to buy with this has 2 spots for 2 aileron servos. However, I already have a radio and receiver, and the receiver has only one slot for the aileron servo. Is there some sort of connector thinig or something I can buy to connect the two aileron servos into one, so it plugs into my receiver. Thanks.
IL
RE: How to make dual ailerons go into one aileron slot on the receiver?
Yes, You need a Y harness. They come in all sizes and shapes so make sure you gat one for the same plug style your using.
Joe,
You can also use a second channel for the other aileron servo, if you transmitter is capable. This is a capabilty that is in most computer radios. What kind of transmitter do you have?
Bobby
Bobby
ON, CANADA
it is not a computer tx, the y harness thing looks like it will work perectly, i emailed the company and the one ill order will work with my jr radio and receivers and hitec servos. thanks.
