Not another SERVO!!!!!!!!!
I have built a large readio controlled hovercraft with a 25cc engine and a large rudder, i have flown it twice and have broken my Futaba s3003 steering servo. Can you sergest another suitable servo that is roughly the same size and weight as my current futaba, but that provides much more torque and power.
I need to get hovering ASAP cause the snow is comming!!!!!
My Feedback: (16)
GA
RE: Not another SERVO!!!!!!!!!
Frank, where did you hear that.
I can say that this is not true because I have a plane that had 6 605 servos and a R148DP (PCM) receiver.
MA
Another good Servo is the Hitec 625, Hitec 645, or if you wanted High torque digitals, the Hitec 5625 and 5645.
Towers Hobby lists the torque and speed specs on all the Hitec or Futaba servos.
I would stay away from the 605's, they have been discontinued by Hitec and Tower has recently depleted stock and discontinued as well.
I bought 2 of these recently before tower Discontinued, They are crap! and will not center correctly. I have read some threads where poeple claim good results but also a lot of people with the centering problem.
Dbow
Dbow
My Feedback: (68)
ORIGINAL: AirBearMA
agree with the Bear here 5645mg will do you fine
