futaba T6XA im new
futaba T6XA im new
hi, i have a plane with 2 ailerons servos, now im going to buy the futaba T6XA. In the planes manual, they say that i need a Y for the 2 servos. Do i really need the Y with this radio? can i connect the 2 ailerons servos directly to the receiver? if yes, where? on 5th channel? can i use flaperons? tks for help
Sorry about my english
RE: futaba T6XA im new
well, im new, but now flying, just building, its not a trainer, is a GP dazzler. And is cheaper and better to not put an Y. Dont u agree, im not going to use flaperons all the time, but i want to try. But u didnt aswer my question.... it works??? how?
Scolpit,
I dont know your specific Fuataba Tx but normally to use two servos on aileron you use channels 1 & 6, you'll probably have to change something in the Tx set up to activate the mix.
If there is no dedicated mix you could use one of the free mixers and mix Ch 1 (Master) to Channel 6 (Slave)
Good Luck
FB
Good Luck
FB
plug the right servo into channel 1. plug the left into channel 6. with xmitter mode button get to FLPR. make sure it is not repeat not inhibited. set % to 0. now check out movement of ailerons. now go to your manual to see how to set up flaperons.
