programming delta mix in a JR 652
My Feedback: (21)
SD
I have a new Zagi flying wing and I punched in the Delta program on my JR 652 radio. This is the first time I have programmed this feature.
It works fine, but the elevator is on the aileron stick(right/left), and the aileron is on the elevator stick (up/down). What am I missing here? I switched the servos around but there is no change. I tried a second receiver and it does the same thing. This has got to be something simple, but I can find no reference to it in the manual.
Thanks, in advance for any help you can give me.
My Feedback: (21)
SD
thanks, that was all there was to it. I reversed the aileron servo and it put everything right, but the ailerons were reversed, had to play with the servo reversing on both seros a while to get it right, but it was as simple as that.
I guess that's what all you guys are for. Thanks.
