Vertical boat antenna housing
Putting together an airboat for ocean/bay use. I plan to mount the antenna forward and I'm looking for options of verical support. Would a piece of carbon fiber tube be a suitable for running the antenna INSIDE ? Would the conductivity of the fiber affect the radio signal?
Any other good options?
RE: Vertical boat antenna housing
if it's bad to have the antenna next to carbon push rods i'd imagine that it's not a good idea to run it through a carbon tube...i may be wrong though.
if it were me i'd just replace the antenna with a piece of music wire and keep everything the same length...
dave
dave
Zagnut Hi,
did not know about the problem with proximity to carbon pushrods. silver sodering a terminal to music wire and crimping ant wire to a small terminal would give the disconnect. (check out my zenoah post Gas Eng Thought of one of your past comments when I saw it!
mr.rc-cam-RCU Good option as well, thread up and secure top end with wire tie end.
