Folding antenna wire
Hi I have this profile plane where I routed the antenna wire underneath the fuse. There's about 10 inches of wire dangling loose at the tail end of the fuse. I was thinking of folding the dangling wire onto the wire that is well secured on the fuse, and stick them together with scotch tape. Will this cause any Rx noise ? Anyone done this before without any problems ? Thanks !
OR
RE: Folding antenna wire
The name for this type a antenna is long wire. If you left it as shipped, about a 2" coil tied in the middle it wouldent be a long wire.
Darryl
Darryl
Antennas are funny critters, they are designed to operate at the signal frequency they are receiving or transmitting. If one folded the antenna wire it is effectively shortening the electrical length and detuning it, making it less sensitive to that particular frequency, hence, loss of signal strength.
DON'T FOLD YOUR ANTENNA! LEAVE IT HANGING OUT OR PIN IT UP SOMEWHERE.
