micro throttle servo suggestions
GA
Hello everyone. I would like some advice concerning micro servos for throttle control. I want as much precision and speed as possible. Any suggestions welcome. Thanks.
My Feedback: (41)
RE: micro throttle servo suggestions
Glow throttles require almost no torque IF you make sure the control rod has no friction in it. Avoid sharp bends and make sure nothing touches it inside the fuse (use hard plastic tube around control rod). If it feels smooth moving it with your hand then you are good to go.
Joe
Joe
NY
Use the fastest micro servo you can find. Like Joe said torque is irrelevent as long as you're control arm setup is good.
