JR 8103 on GP 300 PW elevator servo set up
IN
I was wondering if anyone has used their 8103 on a GP 300 PW and NOT used a Y servo reverser when setting up the elevator servos.
Im pretty sure how to do the ailerons (set up for flapperons) but the set up for the elevator servos elude me. I tried to do it with my JR 662 on a GP Giles 202, but was told the "basic" computer radios dont have the trim and sub trim when slaved to a master. So I had no choice but to use a Y rservo reverser.
Im fairly sure it's gonna have to be one of my programmable mixes. One thing Im concerned about is to make the mix "Always on" AND NOT have it on a switch (in case switch gets moved)
Ill be using a R700 reciever and the gear channel is used for the smoke system.
IN
RE: JR 8103 on GP 300 PW elevator servo set up
I would just like to thank you for that info. That was SO DANG EASY. Now I'm not sure how exactly I did it, but I followed the directions to a "T" and BAM! There it was, programmed. Im stoked up about playing with flapperons, and mixing with elevator. C'mon spring, get hear already!!! Im ready to fly!!!
My Feedback: (16)
GA
Send it to me and let me see what I can do.
ORIGINAL: ritchie_rich
give me your e-mail and i will send it to you
it is save in a big file and won't let me post it
My Feedback: (22)
KS
All,
The XP8103 aircraft programming guide can be downloaded from the JR support site fur-free:
http://horizon.hobbyshopnow.com/shar...amming-air.pdf
Gary L.
Gary L.
