C???HOW TO DELETE ALL INFO TO FACTORY DEFAULT
Hi
Could you please advise me how to go about returning to Factory Default on 9C so as i can re program from start??
Ray
Ray
RE: C???HOW TO DELETE ALL INFO TO FACTORY DEFAULT
You can't reset the entire transmitter, but you can reset any model memory. Just press the Mode/Page key to get to the basic menu. Turn the dial until you get to PARAMETER. Press the dial. RESET will have "EXECUTE" highlited. Press and hold the dial. The transmitter will beep and display "Sure?". Press and hold the dial until the transmitter starts beeping. It will beep about ten times. When it starts beeping, you can release the dial. When it stops beeping, that model memory has been reset to the factory defaults.
Another way is to just go to an unused model memory, if you have any.
To reset all the model memories, you'll have to go into them one-by-one and reset them with the above procedure.
