Which Reciever?
Which Reciever?
OK, I have this parkflier and I'm in need of a Rx. There are a lot of opinions (both neg. and pos.) about every reciever, therefore I need to consult you RCU'ers
I'm thinking of buying an Electrifly.
What do you think?
PS- No one sells Berg Rxes OR FMA Rxes.
What do you think?
My Feedback: (314)
RE: Which Reciever?
I have a few each of the 555's and the Electron 6. These are solid performing dual conversion receivers. The Electron 6 is the smaller of the two and the ones I have work flawlessly. Range is the same as with any of the 8 channel RX's. I use them in my electric planes and in a .25 sized plane and have had no problems. I use mostly Hitec equipment.
MN
RE: Which Reciever?
I've seen problems with GWS RXs:
The president of the club I belong to was flying a GWS Slow Stick. He put an Anstro brushless motor in and souped it up so that it could hover. He was hovering this thing on Ch 36. I walk by the plane on my way out to the flight line to fly my Fokker Dr-1 on CH 46. As I pass his hovering wreck, he lost all control and litteraly RAN after it to regain signal. This happened twice while the Stick was in my radio control zone. After I landed I ask him to check out what was happening. He turns on the plane and his radio. Then I turn on my radio. My Tx was twice the distance from the plane as his Tx was. When I turned on the plane started shakin' as if it was full of ants. The problem was the GWS Rx he had installed.
RE: Which Reciever?
ARGGGG
Just came back from my LHS. Says they don't sell 72 Mhz Electrons or Micro 555's. Now I'm stuck in crap!
Any suggestions?
I think I'll go GWS...but then again....
Suggestions please!
Any suggestions?
Suggestions please!
RE: Which Reciever?
You can not go wrong with getting an FMA M5A. If you ever decide to go to a larger plane, you can even use these in quarter scale and the range is phenominal. A great product in a very small package.
RE: Which Reciever?
ORIGINAL: csisfun
ARGGGG
Any suggestions?
Suggestions please!
ARGGGG
Any suggestions?
Suggestions please!
If you fly away from population or in a park the GWS will work good.
Or, order the FMA from www.alerc.com
Fast shiping.
