400 oz-in Servo
Old 02-05-2004, 04:21 PM
fudge248
Default 400 oz-in Servo
I am looking for a RC servo which can produce at least 400 oz-in of torque and has a range of rotation of 90deg(+45deg to -45deg). I am having a little trouble meeting these needs and would appreciate any suggestion.
Old 02-05-2004, 04:28 PM
Warren
My Feedback: (72)
Warren's Avatar
Default RE: 400 oz-in Servo
The Hitec HS-815BB pushes 350 at 6 volts...
Old 02-05-2004, 04:41 PM
MHawker
My Feedback: (16)
MHawker's Avatar
Any of the Volz servos work? I remember seeing them on a 50% plane at the last TOC.
http://www.volz-servos.com/
Old 02-05-2004, 04:50 PM
mbba2002
Banned
My Feedback: (10)
the only servo you will need is the tone 050 @VANTAC com the servo has +60-60 travel with 900 0z @6 volts.
Old 02-05-2004, 08:50 PM
jc4me2
I don't know if it's any good, but the Hobbico CS-80 has 370 something oz/in at 6V, it's also very fast and only costs THIRTY BUCKS!
What a deal! Does anyone know anything about it? Jordan
Old 02-05-2004, 11:09 PM
Shortman
My Feedback: (21)
Shortman's Avatar
The Hobbico CS-80 is the Hitec 815BB with a different label. Thats the only difference lol
A great servo many people use on GS rudders is the Seiko servo, pushing some 1800ounces of torque I believe, but that is for multiple servo surfaces where the torque is needed.
Right now, best bet would be Futaba 9152's, they have 277 ounces of torque with a extremely strong aluminum outer casing and metal gears. I bet it could handle your application well, depending on what you need it for.
Old 02-06-2004, 12:28 AM
3DFanatic
That 70% Staudacher at the last TOC used Seiko servos.
Old 02-06-2004, 07:53 AM
Boss248
Boss248's Avatar
Check out this web site...they are using the 815 in a special ad on gear drive system that can deliver ome fantasic torque output...it might not be exactly what you are looking for but it is interesting.
http://www.robotzone.com/cgi-bin/sho...tion&key=RZSG1
