More T6XA Problems
WA
More T6XA Problems
Thanks again Stick Jammer for the info. on my mode problem. But I have one more problem with this radio, it's with the throttle trim. When the throttle stick is centered the trim adjustment works fine,but when the stick is moved in either direction the trim adjuster quits working. I tried using the sub-trim but that did not work (just gave me some movement or no movement at half stick). I can't find anything in the manual that would cover this problem. Any suggestions would be helpful. Thanks
IL
RE: More T6XA Problems
The throttle stick action needs to be set to normal. Turn on the transmitter while holding down the two MODE buttons. Then press either MODE button to get to the TREV menu. Use the (+) or (-) key to switch from reversed to normal.
WA
Thats 2 for 2 , thanks again Stick Jammer. That did the trick. Now can you teach me how to fly.( LOL) just joking. HAPPY FLYIN again THANK YOU
