Hitec HS-635HB Servos?
NV
Has anyone used the newly released Hitec HS-635HB servos yet? I've got 7 on one airplane and was wondering if I should expect any suprises? Let me know the good, the bad and the ugly regarding these servos. Thanks.....
RE: Hitec HS-635HB Servos?
635HB specs, Been looking at these too
Control System: +Pulse Width Control 1500usec Neutral
Required Pulse: 3-5 Volt Peak to Peak Square Wave
Operating Voltage: 4.8-6.0 Volts
Operating Temperature Range: -20 to +60 Degree C
Operating Speed (4.8V): 0.18sec/60 degrees at no load
Operating Speed (6.0V): 0.15sec/60 degrees at no load
Stall Torque (4.8V): 69 oz/in. (5.5kg.cm)
Stall Torque (6.0V): 83 oz/in. (6kg.cm)
Operating Angle: 45 Deg. one side pulse traveling 400usec
360 Modifiable: Yes
Direction: Clockwise/Pulse Traveling 1500 to 1900usec
Current Drain (4.8V): 5.3mA/idle and 400mA no load operating
Current Drain (6.0V): 6.6mA/idle and 500mA no load operating
Dead Band Width: 4usec
Motor Type: 3-Pole Ferrite
Potentiometer Drive: Indirect Drive
Bearing Type: Dual Ball Bearing
Gear Type: Karbonite Gears
Connector Wire Length: 11.81" (300mm)
Dimensions: 1.6" x 0.8"x 1.5" (40 x 20 x 39mm)
Weight: 1.83oz. (52.1g)
Dauntae
360 Modifiable: Yes
Dauntae
MI
They are fast, strong, and have surprisingly good centering just like the 5475. Considering its predecessor 605 has really lousy centering, the 635 is a pleasant surprise, especially for the same cost.
