Futaba 9 vap - Please post.
hi guys,
I have a second hand Futaba 9 VAP with 40 mhz module. I would like to know where you place it as far as Futaba tx.s concerned? What I mean is, Should I go for a 9CAP if I decide to buy a brand new one. or a 7CAP or 9 CAP will be better after 9VAP..... ( Also we have a new comer from Graupner(JR) here in Europe - MC 19 - 10 ch PCM-PPM tx which we can consider to get)
MyTx is reading different Volts. Fresh charged battery shows 10.4 V which is normal I believe. Then after 10 min. it is down to 9.6 then another 5 min it is down to 9.2 ... 9 V. Then suddenly it jumps back to 10.4 V. Ä°s it a battery defect or my Tx is not normal....... I havent used it for flight yet. Ä°f Tx is defected then I would consider buying a new one instead of paying for repair.
I would also like to have some info about 9 VAP's How old are they? And How reliable are they? Can I use it with newer synt. modules?
I have another tx a simple Graupner mc12 with 4 ch which I currently use. But my needs are growing I have to use tx with more ch.s....
Thanks for the replies in advance..
Regards.
Zafer
Regards.
Zafer
RE: Futaba 9 vap - Please post.
Futaba 9 VAP was a great radio during its days. That was something like mid from 80's to early 90's.
I have one from 1991. It came originally with single conversion PCM receiver, but the TX is compatible with modern Futaba dual conversion PC1024 receivers.
I have also a 9 ZAP and I can use 9 VAP module in 9 ZAP and vice versa, however synth module does not work with 9 VAP.
There are some issues where 9 CAP outperforms 9 VAP.
9 VAP:
- only 6 model memories and no Campack.
- mechanical trims instead of digital trims (still perfectly usable but a little more work when changing models)
- no flight modes
- little less functions, but enough for most people if chopper modes are not needed
On the other hand the mechanical quality of 9 VAP is far better than of modern Futaba TX's. It was still made in Japan, not in Taiwan as new models.
9 VAP is very reliable if it is well kept. There are cases that aileron and/or rudder pot cables have broken because of bending (while elev and trottle have been used)
10.4 V after charging is not very good, it should be over 11 V, if the battery is in good condition.
Just replace the TX battery and try again.
ini
9 VAP:
- no flight modes
ini
Hi Ini,
Thank you very much for your reply.
As new graupner Mc 19 will be available after September in Switzerland, I will definitly get a Futaba 9 CAP.
As of 9VAP, I will it try with new batt.
Regards.
Zafer
Regards.
Zafer
