Mode 1 vs. Mode 2
Moderator
My Feedback: (58)
RE: Mode 1 vs. Mode 2
Mode 1: rudder/elevator on left stick, throttle/aileron on right stick
Mode 2: throttle/rudder on left stick, elevator/aileron on right stick
What I have seen is that many people who fly mode 1 can do very precision maneuvers with little training. Having the rudder and elevator on the same stick helps you to coordinate turns and maneuvers more easily. It forces you to fly with both hands. Mode two can make you lazy and fly with one hand unless you need to change the throttle setting. Fly the mode which is popular in your club. There's no right or wrong, both modes are OK, it's just a matter of practise
CA
This should answer any and all questions about transmitter modes.
http://www.macgregor.co.uk/faq/stick%20mode.jpg
Mode 2 is the most popular mode in the US. Mode 1 is most popular in Europe and Asia.
My Feedback: (16)
GA
Mode 2 is a farly new mode popular in the USA over the past 25 years. It made transistion from rudder/elevator turns to aileron/elevator turns easier.
Friends...
I live in Europe (Spain) and the most popular mode is the Mode 2 (I use this), but some many people that use your left hand how a best hand, use mode 1.
Really, the way to imitate a real aircraft comander will be mode 1, becouse, in a real plane you have the throttle in the right hand, and the elevetor and aileron must to move with the left hand.
But...some war birds have it in the opposite way...but, you can do it like how you feel better...or like you was learned
CA
ORIGINAL: Geistware
Mode 1 was adopted because it was the most nature change from flying reed systems from the early 60s. My old reed transmitter had ailerons and rudder on the right side of the transmitter and throttle, elevator, elevator trim on the left. Since you use primarily ailerons and elevator, that was why the first proportionals had these controls separated. I like flying mode 1. No one wants to fly my plane
Banned
And a lot of the old (cheap) 2-channel sets (like those from Futaba) used to use two single-axis sticks so the primary turn control was on the right stick and the elevator was on the left. Mode 1 therefore, became the natural transition.
Of course now that mode-2 has become more popular in the USA, RC companies are now making more single-stick 2-3 channel transmitters like the Hitec Neon.
As has been mentioned, mode 1 came from the old reed sets that used toggle switches and bang-bang controls. Proportional control had not been developed at the time. You moved a toggle and you got full elevator or aileron. And you needed a channel for up elevator and another one for down elevator!
Mode 1 has other advantages from a human factors standpoint. For example, you decouple the roll-pitch commands. You can set a roll rate, and adjust it, with one hand, while making rudder and elevator corrections for aileron rolls, point rolls, slow rolls, rolling circles with the other hand. There is something to be said for that.
There are also 2 other modes, 3 & 4. Their definition varies depending on which radio you use. Mode 3 on JR and Multiplex is a left handed mode 2 with aileron-elevator on the left stick and rudder throttle on the right. I fly this mode as I am strongly left-handed dominant and flew control line for many years left-handed. Horizon will set new radios up for lefties if you ask. The Multiplex Royal Evo 12 has the settings in software. You just program in which ever mode you like and adjust the ratchet on the stick (both sticks have them available). Mode 4 is a left-handed mode 1 with aileron and throttle on the left and elevator and rudder on the right. I have seen some Europeans and Canadians flying this mode.
Earlier Futabas I have seen reversed the mode 3 & 4 definition.
TN
ORIGINAL: Ed_Moorman
