Dual Servo?
Reply
Old 04-02-2004, 03:46 PM
KW_Counter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Dual Servo?
Hi,
Does anyone make a dual servo?
By this I mean two servos in one over sized box.
This could be useful for setting up ailerons, especially modifying an ARF, so you can do flaperons.
One large servo being easier to mount than two.
Also could use it when running flaps with ailerons. One dual servo for each side of the wing.
Just an idea that I thought would make sense. Maybe one of the manufacturers could comment on this.
KW_Counter
KW_Counter is offline
Old 04-02-2004, 04:08 PM
Montague
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Dual Servo?
Many years ago Kraft (I think) made a "brick" that had the RX and a couple of servos all in one big box.
I've never seen anything like what you're talking about though.
I have seen guys widen or otherwise modify the opening in the center of the wing, use servo tape to stick two servos togther, and mount two smaller servos together where one larger servo should be to drive torque rod style aileron linkages so they could set up flaperons. It's easy enough to do. You do need to trim some arms off of the servos so they don't interfere with each other.
Montague is offline
Old 04-02-2004, 08:07 PM
radray
radray's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Multiplex makes a brick 7 channel receiver and 2 servos and switch in one unit:
http://www.ss16.dial.pipex.com/Multi...vers/Brick.htm
radray is offline
Old 04-03-2004, 01:16 AM
3DFanatic
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yup
3DFanatic is offline
Old 04-03-2004, 10:41 AM
KW_Counter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
That is some very interesting info, thanks to all. I see some neat concepts there. They mentioned the units are primarily for gliders and I'm a glow man myself.
In reading it they mentioned different height servo arms to prevent collisions of the two. Is this a readily available item - even by other manufacturers?
KW_Counter
